![]() | Home > Maintenance & Modifications > Lower Control arms |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi just had both my lower arms replaced make sure they replace the bolts and mark the concentric bolt outer shim to make sure the alignment is back to as it was.Mind it’s always worth getting the alignmen checked and set back up also.Got the work completed by my local 4x4 Land Rover Indi. |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 ![]() ![]() ![]() |
What was the cost if you dont mind me asking? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Fitted these Meyle one's on mine, good quality and fitted spot on with no problems. Personal opinion any at £120.00 a pair = cheap and nasty.
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
And don’t buy cheap bolts either….must go oem….they are torqued up tight and cheap ones are like cheese…
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1181 ![]() ![]() ![]() |
Dropped by TWT because I felt a slight pull to the left.
^ LR stealer refuses the warranty claim |
