![]() | Home > General > 2005 RRS Headlamps |
Main beam is made up of 2 bulbs.
2eZero Member Since: 04 Aug 2021 Location: West Midlands Posts: 9 ![]() ![]() |
Aim is fine on dipped, but main beam is the one that's out.
Yeah. Hope it’s a miss aligned bulb
On the pre-facelift models, there are two adjusters on the headlights. You can adjust them in the same direction to raise/lower the beam, change them separately/differentially to change the left/right direction.
Thanks for that information RRSTDV8. I thought that the H7 outer lamp was the only thing for main beam. The bulb hasn't gone but it is significantly higher.
