![]() | Home > Technical > Differential Differences |
Petrol or diesel?
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
The Supercharged petrol uses the 3.54:1 ratio, the Naturally Aspirated petrol uses the 3.73:1. Later cars with 8 speed box use 3.21:1
I did wonder if the workshop manual was correct as it seems to have info that doesn't agree with itself! |
Just had another look at different editions of the W/S manuals and they do contradict themselves a bit, found another bit that say's N/A petrol engine if it happens to have the electronic locking diff it is the 3.54:1 ration, so who knows, L/R don't appear to and they build the things. |
Coleman19d Member Since: 08 Jul 2021 Location: North Lincolnshire Posts: 7 ![]() ![]() ![]() |
Diesel Models in particular.
You will have a Centre diff lock on your Sport. I have never not gotten anywhere that a car with a rear locker as well as the centre locker fitted has gone. Maybe slightly less drama with a rear locker installed, instead of just relying on centre locker and traction control, but you can still get just as far if not quite as graceful |
Someone did retro fit the locking rear diff to a Sport (or Disco?). I remember reading a thread about it somewhere. It was a while ago. A bit of a job to do but perhaps better than an aftermarket one because it works with Terrain Response and the various ECUs in the same way as the centre diff lock.
