Home > General (L494) > Several faults - earthing issue?
Norniron
Hi All
The car has recently started generating a number of faults, including bonnet open (it's not), coolant level low (it's not), park brake fault (working fine), adaptive cruise, IEB and forward alert not available (working intermittently). On top of this the left hand headlamp assembly as been working intermittently, with the DRL flickering. The last couple of runs the complete headlamp is out including indicator, DRL dip/main beam. Another strange thing is the ECO stop/start sometimes doesn't start the engine once stopped and I have to press ignition switch to start her up again.
These issues had started to appear intermittently and I assumed new battery required, but fitting new battery hasn't cured the issues.
Having read through other posts, I'm now thinking this could be a bad earth causing these issues.
I've removed the front left hand wheel arch trim and had a look for earth wires there. There were a couple of thin diameter black wires attached to a circular connector which was bolted to the inner arch, but these looked in good condition, with no visible corrosion. Are these the earth wires for the circuits effected? Are there others I should be inspecting and where are their locations?
Hopefully someone can shed some light (pun intended!) on this issue.
Thanks in advance
Post #616924 Tue Aug 31 2021 2:36pm
Eaters
It would be helpful if you completed your profile so that we know the car details (age, fuel, etc.)
Certainly on older models a classic fix is to renew the brake light switch and ensure you have quality brake light bulbs as this can throw up all sorts of wobblies. But letting us know what you are driving will help. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #616925 Tue Aug 31 2021 2:50pm
Norniron
Thanks Eaters. Car is 2014 Autobiography SD6 with 90k miles
Post #616930 Tue Aug 31 2021 3:17pm
Red Arrow
I had exactly the same issue and it was the headlamp earth strap requiring attention Thumbs Up
Post #616934 Tue Aug 31 2021 6:38pm
Disco_Mikey
Earth point in the respective wheel arches. Seen quite a few of these now Thumbs Up
Post #616935 Tue Aug 31 2021 7:10pm
Norniron
Thanks for the responses guys.
I had the wheel arch liner off on the front left side but couldn't see an earth strap there. What am I looking for and what is the exact location of this? Does the strap attach directly to the headlamp? Anyone have photos?
Thanks Leigh
Post #616939 Wed Sep 01 2021 8:12am
SC247
I had this same problem my fault was traced to the main battery earth to body stud it was loose a known manufacture issue not toqued correctley
Post #616961 Thu Sep 02 2021 8:27am
