![]() | Home > Technical > ACC problem tdv8 sport |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
If you are referring to the Radar Sensor it is behind the front bumper on N/S side, the Control Module is behind the trim panel in the N/S footwell looking at this diagram.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Interesting.
Just noticed that drawing is a L/H/D illustration so control module may be in the O/S footwell.
Jefus957 Member Since: 26 Aug 2021 Location: Stoke on trent Posts: 5 ![]() ![]() ![]() |
Thanks for the info will keep looking, its annoying that the initial fault was cruise not available and a scan with the icarsoft vr2 gave adaptive cruise speed module fault, cheers Jeff |
