Home > Maintenance & Modifications > RRS L320 2013 HSE:New front wheel hub bearings
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi just some advice I’m getting new lower arms fitted at front as bushes worn i have new front disks and pads to go on but getting the garage to do these at same time and saves me doing it.My RRS L320 2013 HSE has 63000 on clock I was thinking maybe time to put new front wheel bearing hubs on while they do the other stuff as they will already be stripping it all down .I have 2 new units bought from Advance Factors with the forum discount code arriving next week.Do you think it makes sense to get these replaced at same time ?.As ever thanks in advance for your thoughts folks. Thumbs Up
Post #616602 Sun Aug 15 2021 3:39pm
knwatkins
Unless your bearings are shot, there is no reason to replace.
The only thing in common between replacing the lower arms and replacing the hub assembly is removal of the wheel. Wink It's a completely different job. Kev
Post #616605 Sun Aug 15 2021 7:37pm
