Home > Technical > Low fuel level warning !!
Bulldog
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Anyone else had this issue. My fuel level is working correctly I think but my previous RRSs have had the low level warning light show and then the sat nav shows petrol stations. This is not happening with this one ? I thought the low level warning was linked to the digital fuel gauge and illuminates on about 45 miles remaining
I think the fuel gauge looks a bit high for only 20miles remaining ? Pic in gallery
It’s a 2010 my TDV8 3.6 autobiography
Cheers in advance.
Post #616567 Fri Aug 13 2021 5:44pm
gogsy1956
Maybe the "20miles remaining" isn't correct,, as you say the gauge is showing a little high for the low level to illuminate, mine drops right into the bottom quarter before the warning comes up. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #616568 Fri Aug 13 2021 7:33pm
Bulldog
Hi
I don’t suppose you have a pic of yours ? As I understand it the car calculates miles remaining based on fuel level so something does not add up !!
Post #616570 Fri Aug 13 2021 9:26pm
gogsy1956
I very rarely run the tank down to low level so could only give pictures of half full and more. The other ting the trip computer takes into account is the MPG which is why the readings will differ depending on whether you are getting 18MPG or 28MPG. The low level will always come on at the same point on the gauge,, which is quite low,, the stated miles remaining will be based on your current mpg. 2010 RRS, TDV8
22" overfinch
Post #616579 Sat Aug 14 2021 12:08pm
Bulldog
Hi
After looking at Topix, it says low level light should come on when approx 12 litres of fuel remain. This is not dependent on MPG. The car calculates distance remaining using fuel level and driving speed load etc. This is what leads me to think something is not working correctly.
Post #616580 Sat Aug 14 2021 12:42pm
gogsy1956
That's what I said,,, the low fuel will come on at the same point on the gauge,,, 12 litres of fuel in an 84ltr tank is not very much so expect the light to come on way down the scale. The computer will estimate how many miles are left using your current mpg. Many a time I have filled the tank and the display said I had 285 miles available,,, after a 300 mile round trip averaging 26mpg,,, filling it again would show 320 miles available. The low level is fixed in stone and is "x" amount of fuel,,,,, the mileage remaining fluctuates with your driving style and changes constantly. I think you are worrying about something that doesn't exist. 2010 RRS, TDV8
22" overfinch
Post #616587 Sat Aug 14 2021 6:31pm
