Home > Technical > parking sensors
Kevin-t
parking sensors
Hi Guy's.
Moved over from a Disco 3 to the sport. Had parking sensors on all the time in the disco. However don't seem to be able to keep my parking sensor on in the sport as it did on the disco.
Can switch it on manually when parking forward, however the light goes out when stopped and then I have to manually switch it back on. Should it be on permanently, is there a setting to have on always?
I don't mean the green triangle sensor, for moving traffic too close I fathomed that out. Just the parking sensor!
Hope that makes sense!
Kevin
Post #616523 Wed Aug 11 2021 9:57am
Which model RRS do you have? Original L320, facelifted L320 or one of the L494 versions? 2012 SDV6 - it's missing a couple of cylinders
Post #616526 Wed Aug 11 2021 12:05pm
Dave-t
Mine come on (front and back) after selecting reverse and both stay on until you go forwards over a certain speed, around 25mph I would guess, or switch off the ignition Joined the X5 45e club
1994 Defender 90 300 tdi
Post #616528 Wed Aug 11 2021 12:20pm
Kevin-t
2016 L494 A/B..4.4
In the old Disco the parking sensor light was lit up permanently, but only beeped when close to obstacle. Maybe it needs setting some how!
Post #616529 Wed Aug 11 2021 12:25pm
Very early on in the disco life they considering leaving them on a bad idea Sad so changed the ecu.
I don’t think you stand much hope in reconfiguration.
Post #616531 Wed Aug 11 2021 1:33pm
dav.a
Scotland 2011 Range Rover Sport SDV6 HSE Java Black
Re: parking sensors
Kevin-t wrote:
Hi Guy's.
Kevin
Same with my 2011 RRS
Post #616663 Wed Aug 18 2021 2:51pm
