![]() | Home > General > Please help HDC trans fault engine failure |
Need to see if you have power at brake switch with ign on (the red wire and the green/orange wire)
Only a thought but you didn't press the brake pedal by any chance while changing the switch as this can damage the switch.
yes that is true in a way
Be worth checking all of the earth connections. Not unknown for a loose one to cause a spate of issues.
Jjmorris90 Member Since: 15 Jun 2021 Location: Leicester Posts: 12 ![]() ![]() |
I watched a video on YouTube to put it in. Defo didn’t press the brake pedal. I got it from eurocarparts £9. So don’t know if that would make a difference to a genuine one. Brake lights still don’t work. |
HDC fail park brake fail suspension off special programs off engine fault |
Okay so quick update. There was no fuse in fuse 15. Popped one in and no faults now except engine fault |
what fault code does the engine say ?
Can’t see a fault code as I’ve no code reader. It was my friends who I used. It just says engine fault on the little screen |
That was a TDV6. Seems our new friend has a penchant for broken RRSs... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
It needs to be code read by a LR-friendly code reader. Most generic ones won't pick up all of the fault codes. Trying to sort out a broken RRS without a decent code reader is just making a hard job in to an impossible one. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Ha yeh I get suckered into buying faulty ones. Too gullible. That once was a blown ring on the injector. Sorted it |
