Home > General > Should the roof rail be capped off? *PIC INSIDE* |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
The blanking caps covering the mounting screws holes are missing thats all nothing else missing. They are quite a odd shape and size, unfortunately as normal L/R do not list them separately for the Sport, however they do list some for the D4 roof bars that look the same or very similar so may be worth a try. Part No. DBD500020PVJ
Wed Jul 21 2021 10:09am |
Agent_Trig Member Since: 29 Jun 2021 Location: Staffordshire Posts: 43 |
Would those be grommets to cover the circular holes?
Wed Jul 21 2021 10:46am |
Yes they are, a L/R dealer or just google the number and see what comes up.
Wed Jul 21 2021 10:50am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
I wouldn't say they are "grommets" per se, more like a little plastic cap with a bit out the edge so you can get a small screwdriver in to lever them off. Definitely not rubber. If your bolt is tight, then it shouldn't let water in, they're just cosmetic. |
Wed Jul 21 2021 5:52pm |
I haven’t got anything bolted in, as not got any bars or roof rack.
Wed Jul 21 2021 5:54pm |
I have fitted several new genuine L/R roof rail kit's and the only thing you have missing apart from the cross rails not being fitted are the caps shown in the picture, there are no full length covers.
Wed Jul 21 2021 9:13pm |
Eagle77 Member Since: 21 Feb 2021 Location: Buckinghamshire Posts: 69 |
What model do you have? If its a L494 you just have a stock roof then yes something is missing and that should have a cover to make it flush with the roof.
Thu Jul 22 2021 3:13pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
I know what you mean. I bought some genuine LR ones from Buckster on this forum. They are great and the bars have come in really handy. However, they do look unfinished but apparently this is how they are. And from the ground of course no one knows except you. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Fri Jul 23 2021 12:39pm |
