![]() | Home > In Car Electronics > M.O.S.T ring break |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
Could be a break in the optical fibre. You can test both ends with a torch.
grimreaper Member Since: 18 Oct 2020 Location: Cheshire Posts: 18 ![]() ![]() ![]() |
Thanks for your insight Andy K will do the torch test tomorrow, what does changing out the head unit entail if you dont mind enlighteningm me TIA
don't know sorry.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Easy enough to remove head unit if needed,
Thanks Col further to my last post the Dab icon and cd soft keys are grayed out the radio button is pressable but does nothing
further to this problem diagnoses of my car took place today seems that the head unit is caput or needs software update,as the car was in the other month for a sat nav update I have p[lumed for a used head unit which I will have to get recoded through the main st(d)ealer hopefully that will be easy enough because you can now do it online through land rover fvor £20.
