Home > Technical > Car won’t run and has no engine faults |
Darkangelv2 Member Since: 01 Jul 2021 Location: Romsey Posts: 25 |
Hi Trevs
Mon Jul 19 2021 8:06am |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
does it crank over? |
Mon Jul 19 2021 11:44am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
It needs to be taken to a decent independent LR specialist. There are codes showing the RAC screen you show but they are down as "unknown". Lots of code readers don't pick up all of the LR ones or they give just partial codes. 2012 SDV6 - it's missing a couple of cylinders
Mon Jul 19 2021 1:06pm |
That would be my thought also. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon Jul 19 2021 7:15pm |
