Home > Technical > Suspension calibration
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
I have checked the calibration values for my car can some let me know if these are correct in the picture
Thanks
Cosmo
The photo has gone to my gallery
Post #615407 Sat Jul 03 2021 12:28pm
The values aren't millimetres, they're just a figure that the system uses to know whether the wheel is moving up / down. SO there is no right/wrong value in the calibration. If you measure the ride height at each corner, are they all the same within 10mm? 2012 SDV6 - it's missing a couple of cylinders
Post #615409 Sat Jul 03 2021 1:06pm
Cosmo15555
I have checked the measurements
Front from tarmac to centre wheel arch 80cm
Rear 82cm
Post #615511 Tue Jul 06 2021 6:08pm
Flyfisherman
Measurements should be taken from centre of wheel to centre of arch. If memory serves me right it should be 460mm front and 465mm rear.
Hope this helps Richard
Post #615517 Tue Jul 06 2021 7:33pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Have you followed the relevant section in the IID user manual? Around page 105 onwards.
IIRC They provide full instructions together with a worksheet for calculating the new values to calibrate your heights. As mentioned above the standard measurement that you're aiming for with your tape measure from wheel arch to wheel centre after calibration is 461mm front and 465mm rear. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #615518 Tue Jul 06 2021 7:51pm
Cosmo15555
Thanks for the info guys
I’ve just gone through the process and readjusted the suspension
Post #615566 Thu Jul 08 2021 5:59pm
