![]() | Home > Technical > Black smoke on hard acceleration |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
Intercooler hoses are quite a common issue,, easiest place to start looking. 2010 RRS, TDV8
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
When my hoses went I had no smoke - just went into limp mode to get me home. But, as Gogsy says, and as you planned, the hoses are a simple and easy way to start your analysis. Also a fault did show on the fault code data. Check they are using a decent fault diagnosis tool Robin
Kev H Member Since: 26 Apr 2020 Location: Lichfield staffs Posts: 12 ![]() ![]() ![]() |
Yes it was the long intercooler hose so gaffa tape on has confirmed and new hose on order, and thanks for your input. |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Thanks for posting the outcome Kev. So frustrating when someone raises an issue and we never get to know what the issue was. |
Yes totally agree with you Barrie and just fitted new intercooler pipe £12 off ebay a bargain |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
Hi Kev, i have the same issue, can i ask was the pipe hard to fit |
The top hose is an easy fit as it's all nicely accessible and the fittings are simple. The ones buried down the side of the engine are more "interesting". 2012 SDV6 - it's missing a couple of cylinders
