![]() | Home > General > Hi guys new owner questions appreciate any help |
Would at least get them to replace the H/Bake motor, assume they mean plastic housing cracking could lead to water ingress and failure in the future around £200.00 for a new one.
jorgefrankie Member Since: 26 Jun 2021 Location: Cheshire Posts: 3 ![]() ![]() |
thanks for the reply Col |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 158 ![]() ![]() ![]() |
MY 14.5 - I've had the arc pipe misting issue, replaced the pipe from the pump to the first joint, seems to be from where the alloy pipe is crimped to the high pressure flexible section. Never lost any fluid but annoyed me so I replaced it. Easy job to do, if you buy the pipe it comes with the seals for both ends so don't go buying those separately. |
