![]() | Home > Maintenance & Modifications > Rusting around rear power sockets |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
its fairly normal that that panel looks rusty
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
You can actualy buy the crossmember separately, but it would be a lot of work as its welded in not bolted, I think L/R did replace a few under warranty when they were having the worn tow hitch issues which might be why it is available, best suggestion wire brush and tin of hammerite .
It's just cosmetic really. If it's an issue for you, you could just use a rust eater/preventer on it. Taking the rear bumper shroud off isn't too tricky and this would give access to it and the whole cross member. 2012 SDV6 - it's missing a couple of cylinders
adriansj Member Since: 19 Feb 2021 Location: Swindon Posts: 5 ![]() ![]() ![]() |
How do you remove rear bumper shroud? |
Remove mud flaps
