Home > Technical > Suspension fault
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Suspension fault
My car has developed a suspension fault
While driving a message comes on display along with red triangle warning stating suspension fault max speed 30mph then a message forward alert disabled and orange triangle for this
The suspension lowers to bottoms out
If I turn the car off then restart the engine the fault clears and suspension rises to normal height
The fault code is in picture uploaded
Any help would be gratefully received
Thanks
Cosmo
[img]https
[img:800:368]https://www.rrsport.co.uk/gallery/albums/userpics/20005/normal_7BA4EE1C-6D1D-413A-AF16-31ABFD677376.jpeg
Post #615134 Thu Jun 24 2021 10:47pm
It's a failure that can be caused by two height sensors giving weird readings, or it could just be that the calibration has become corrupted. If the sensors give what appear to be bizarre readings for heights, the system assumes it's gone wrong and sticks the car on its belly. This being the safest ride height - you wouldn't want to be whizzed up to super extended mode at high speed, for example, as it could become unstable.
If your fault reader can do live values, it would be useful to see the four ride height readings. 2012 SDV6 - it's missing a couple of cylinders
Post #615141 Fri Jun 25 2021 10:26am
Cosmo15555
I have iidtool so will check live values
Thanks for the reply
Post #615153 Fri Jun 25 2021 2:00pm
You can check the calibration too, of course, with the IIDTool.
Remember that the values in the calibration aren't actual dimensions in mm, they're just values that the sensors work through. So your calibration can look very odd with each corner showing very different values. It's what they do when working that will be helpful to you. 2012 SDV6 - it's missing a couple of cylinders
Post #615157 Fri Jun 25 2021 3:30pm
Cosmo15555
I’ve had a quick look at the live value features for the suspension but there are so many different live values to look at do you know which would be the 1 to look at
Thanks
Cosmo
Post #615233 Mon Jun 28 2021 10:25am
