![]() | Home > Technical > Fog lights |
Could be a wire rubbed behind the front bumper.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Will check the fuse tomorrow, also noticed the symbol for the fog lights on dashboard did not work either, would a blown fuse also stop the fog light on the dash to not display? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Quick look at wiring diagram if I read it correctly the instrument warning lights are powered of the same fuses as the lamps, both front and rear fogs are on different fuses, No. 38 for the fronts and 32 for the rears although No. 44 is mentioned as well in the diagram but diagram could be wrong as that is listed as transmission shift display or something like that. That's on a pre-facelift car.
Thanks Col, I have a 2006 pre facelift, are the fuses located in the glovebox or engine bay? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Glovebox.
Thanks Col |
This diagram shows as fuses 38 and 32 so looks like the other one is wrong I think.
Yes Col I bought the AB bumpers off you, I think it was about 6 years ago for my s/c RRS just before you moved away |
100% agree with you. You shoulld not even think about buying a S/C if you are worried about cost & economy |
The fuse or link in the top left (purple wire) was the one I was thinking of. |
Worth Checking, could explain why both front and rear fogs have packed up seeing as they are on separate fuses.
do u know what fuse number that would be please? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
will have a check later on and see if any other fuses are blown RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
