![]() | Home > General (L494) > New 2021 Keyless Entry Theft Concern |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
Best thing is put a track on it with txt call alerts, if OGC want the car they will follow you about and work out you daily patterns and where it might be left un attended, then just turn up with a trialer and lift it on the back, anyone wathcing it will just assume you havent paid your bill!
Sir_Les Member Since: 14 Jun 2021 Location: Leicestershire Posts: 16 ![]() ![]() |
On the build it says it has Secure Tracker Pro 12 Months. Thanks for the advice..... |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1854 ![]() ![]() |
Relay method show not work.......
https://www.landrover.co.uk/ownership/guid...295-405792
Eagle77 Member Since: 21 Feb 2021 Location: Buckinghamshire Posts: 69 ![]() ![]() |
My RRS is a few weeks old - I keep my keys in a Friday box bought off amazon it works well and stops all signals plus has the added benefit of me not having to look for my keys in various pockets. I also have a disklok which I use if leaving the car somewhere for an extended period.
yep sounds like you are covered, mine isnt new but is locked away in a garage over night with cameras. I was also thinking of getting either some Tile chips or the Apple ones and just randomly scattering them under the carpets as well as a tracker.
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Or you could disable the keyless entry.
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Later JLR car remotes go to sleep if not moved for a short time so get around keyless issues. If they want it, they will get it. So best tricks are make it less easy for them and make it obvious! Cameras, flashing LED's, disclocks etc. If they have a choice of two, make yours the hardest or least desirable. 2018 SVR |
Marv11 Member Since: 21 Feb 2021 Location: West Yorkshire Posts: 17 ![]() ![]() |
If it any use, I asked my dealer when I picked up new car - he said the new 2021 fob has been amended so stop easy picking up the signal and transmitting to a car! How true that is, not sure - I still bought a box from Amazon to put the key in, along with CCTV on the car and the drive down to house! |
Just what I said, it is true, squared off remote are the ones. 2018 SVR |
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 ![]() |
Disable keyless entry, you know it makes sense, surely you are not too lazy to press a button to open a door? |
Problem is that only stops them.openimg the door, at this level, that's nothing. Not a Ford Focus. Keyless enter is disabled when the remote is stationary, leave it on a table still when at home etc. I would leave mine not a million miles away from the door. If they want it, they could come through the door for the keys. Like I said, make it as less desirable as possible, enjoy what you have! 2018 SVR |
Id rather let them take the car if I’m honest rather than come in the house it’s an object, it would be a pain but but better than a burglary at the same time!
dadio77 Member Since: 30 Apr 2021 Location: Worcestershire Posts: 11 ![]() ![]() |
I thought I was the only one to take this approach - I currently leave keys near the front door, not because I want my motor to be stolen, but I'd rather they don't enter the house and go looking for them! |
