Home > Technical > brake light failure
MK stylee
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
brake light failure
Hi All,
First post so hello everyone,
2012 L320 Brake light does not light up , indicator, night lights , reverse all fine , Hugh level and right side all fine , Just the left brake light not working, Replaced whole light cluster, no change?? Replaced the brake sensor switch behind the brake pedal, no change, checked fuses no change???
Any ideas please???
MKstylee
Post #614428 Mon Jun 07 2021 10:28am
gogsy1956
Time to start checking the wiring for damage, not sure which way the wiring loom runs,, thinking it might be along the bottom of the door area then up into the boot area. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #614434 Mon Jun 07 2021 11:29am
Did you actualy check for a feed in the vehicle harness with a multi-meter before replacing the the whole lamp? green and purple wire if I remember right.
Post #614437 Mon Jun 07 2021 11:52am
MK stylee
Green and purple
I’ll check
Many thanks
Post #614463 Mon Jun 07 2021 4:47pm
MK stylee
UPDATE!
had my garage have a look and he just plugged it in to the diagnostic machine , and said' There's a fault I'll reset it ??
Works fine , Just a glitch???
Thanks anyways Guy's
MK
Post #614973 Mon Jun 21 2021 7:15am
