Home > Technical > Suspension warning
Blank one
Suspension warning
Hi new to the forum so go easy 😂
Just picked up a 2010 3.0 HSE all was well until the dreaded bing bong, this is a complete new one to me (had quite a few RR’s & Disco’s but never had a Stop immediately, Stop safely, Turn off engine message before?
Done the usual internet search but can’t find much out other than maybe low fluid, I do have an IID tool which I will plug in tomorrow as left car at mates place and IID at home 😱
I did plug it in on collection and there were zero faults which I did find unusual as every other Land Rover I have bought has had loads of stored faults.
Any advice on this one would be much appreciated TIA.
Post #604400 Wed Sep 09 2020 8:34pm
MICKD777
hi
i have the same fault
topped up the fluid levels serviced the vehicle
checked all connections /sensors under the vehicle relating to suspension
diagnostic run 5 times no fault codes , did a complete reset, still have the fault ?
Post #614923 Sat Jun 19 2021 9:44am
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
I would get a proper scanner onto them. A generic won't show the same as iid or jld I doubt or allow the same tests to be carried out.
Post #614931 Sat Jun 19 2021 2:16pm
