![]() | Home > General (L494) > Rear Diff Pinion seal slight leak |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 ![]() ![]() ![]() |
Google SSM72080 not uncommon problem, contains info. regarding fault and available seal repair kits.
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 ![]() ![]() |
This is a known warranty issue - not sure if you can chance your luck with LR and see if they could do a "goodwill" discount.
rr888 Member Since: 07 Jan 2014 Location: Merseyside Posts: 4 ![]() ![]() ![]() |
Ok great thanks guys, i was also after some info ref changing the seal itself ? at Home |
This might help, but may have been re-issued by now, does look like few special tools could be needed.
