Home > Maintenance & Modifications > Facelifting my L494 to the 2018 Style - Project |
nick09@live.co.uk Member Since: 08 Jul 2020 Location: East Yorkshire Posts: 5 |
Hi have you a link for headlights? I’ve looked but there is so many thanks |
Tue Jun 15 2021 8:24pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 |
Only way is genuine headlights and have them converted and coded for the earlier model |
Tue Jun 15 2021 10:57pm |
CountJunkula Member Since: 28 Jan 2016 Location: Wolverhampton Posts: 15 |
That's not true..you don't need to have any coding done, it depends how they're fitted and/or if it comes with a PNP harness. When people first started doing this conversion yes it was a big job and they had to be wired into the light module and coded in. But since then they have developed plug and play wiring kits that just work immediateley. Everything works 100% as it would normally, no coding or wire cutting. The lights I bought come with the full plug n play harness.
These are the ones I bought, (the second set that are very good). They are genuine lights but the branding has been removed (they scratch the logos and put a sticker over it, but when you peel the sticker back you can see the Land Rover and Varroc logos, all LR stickers are there with part numbers etc. Plug N play, easy install, come with ballasts etc. They're definietely RHD and fully MOT legal. Just double check that they are sending you the RHD versions because they sell both RHD and LHD units. https://www.alibaba.com/product-detail/Hig...2fc2NkoXL0 I was dealing with a lady called Christie, if you tell her that I (Nick) gave you the link she might do you a deal. |
Fri Jun 25 2021 2:08pm |
Just to add to this again..
Fri Jun 25 2021 2:25pm |
mariwun Member Since: 20 Jun 2021 Location: london Posts: 3 |
Do you know how I can get this effect with original used headlights? |
Mon Jul 19 2021 11:31am |
IanV8 Member Since: 06 Jan 2020 Location: Dunfermline Posts: 60 |
Now you need to change the red badge.
Tue Jul 20 2021 8:43am |
yasdin Member Since: 06 Aug 2021 Location: London Posts: 4 |
Hi Guys,
Fri Aug 06 2021 9:19pm |
You need to change the bumper support/ carrier for the 2018 onwards one - cost around £60 from the dealer
Sat Aug 07 2021 11:19am |
Hi, Thanks for hte reply. i do actually have thew new bumper support but as per the pictures here, this is seperate to the holes that the lights go into (which is the bumper support bracket / headlight bracket, Number 1 in the below image.
Sat Aug 07 2021 11:52am |
No , not number one on the image , its the part with what looks like a row of teeth and is shown on your photo with the white clip on it , this looks like the original part ? |
Sat Aug 07 2021 12:33pm |
sorry wrong picture! I havve this bumper support a new one that came with the body kit, this fits fine,
Sat Aug 07 2021 2:16pm |
Not sure then, are they genuine headlights ?
Sat Aug 07 2021 5:20pm |
RRSstocks Member Since: 18 Aug 2021 Location: Yorkshire Posts: 1 |
This is an extremely useful post.
Tue Aug 24 2021 11:15am |
Thanks for the feedback, I’d be happy to give you any advice but I wouldn’t be able to actually help with the conversion unfortunately.
Sat Aug 28 2021 7:48am |
