![]() | Home > Technical > Suspension Fault C1A20 |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi if you are getting the "pressure increases too slow when filling reservoir" (C1A20) code and you can hear the compressor running okay, it may be you need to get the dryer cleaned/replaced and the valve refurb kit. |
Jontee Member Since: 05 Feb 2021 Location: Crieff, Scotland. Posts: 10 ![]() ![]() |
Hi Iomegas, Had thought the same as you, it seems most folk who get code C1A20 do just that, it sorts it for some &
Hi no problem i hope you get it sorted ok . |
