Home > Maintenance & Modifications > Rear wiper blade change |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
The end of the arm has a "U" shaped hook that the blade fits onto. To remove it you don't have to lift it too far off the screen (from memory there is a small tang on the blade that you have to press in/flick out; not sure which) and pull the blade back towards the spindle. The arms do benefit from a little lubrication at the hinge close to the spindle to keep them free.
Thu May 27 2021 7:30am |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
Just change the whole arm and blade for a newer modern plastic one, Can get a arm and blade from ebay for less than £15 and it looks alot better and more modern that the agricultural metal one. they actually have a better spring too so a better wipe, and much lighter, every gram on this beast counts lol. |
Thu May 27 2021 8:36am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4944 |
dunno if this works but ..... if desperate.
Thu May 27 2021 11:30am |
Sansonneche Member Since: 29 Mar 2021 Location: France Posts: 2 |
I don't think it matters where the wiper is. I think maybe changing the whole thing is going to be easier, trued everything, can't get the bloody thing off! If a man speaks in the forest and there's no woman to hear, is he still wrong? |
Thu May 27 2021 2:06pm |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 |
Hi I had problems with mine I ended up using a small puller tool on the arm to remove it all together and then replaced the blade. |
Thu May 27 2021 2:11pm |
Gumby Member Since: 04 Apr 2021 Location: London Posts: 12 |
I just replaced mine too actually - it's a bit fiddly but you can just press the tab down and slide it out when it plays ball.
Tue Jun 01 2021 5:34pm |
