Home > Technical > Error on Rear Windows
hullstorage
United Kingdom 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Hi All,
So this is quite confusing, well to me it is lol ?
Nearside Passenger side window will only go down at the switch and also the drivers switch so will not go up at any switch.
Offside Passenger will only go up at the switch but will go up and down at the drivers switch ?
Has anyone had this before ?
Ive checked what fuses i can see and all looks well, ive been told it could be body control unit ?
Any advice please before the auto electrician is called
Thanks
Post #613785 Wed May 19 2021 2:33pm
thankfully won't be the body control unit.
It will either be switches at fault or a wire break going into one of the 3 doors
YOu could try swapping the rear switches and leaving them loose to see if you get any change
Post #613787 Wed May 19 2021 3:01pm
Brit Plumber
Yep, sounds like you have switch pack issues. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #613808 Thu May 20 2021 10:38am
