Home > General > Detachable tow bar |
Phil23 Member Since: 02 Sep 2019 Location: Scotland Posts: 28 |
Afternoon All.
Tue May 11 2021 1:27pm |
RRSSDDUB Member Since: 31 Mar 2021 Location: NE Posts: 28 |
mine looks like this
Tue May 11 2021 1:34pm |
Wed May 12 2021 11:58am |
If I remember correctly there are 2 versions, the 05 to 10 and then the 10 onwards. The only difference as far as I’m aware is the plastic lock parts and they are interchangeable. So it shouldn’t matter which you get, it’s just one is a revised model. 2019 5.0 SC SVA (Current)
Thu May 13 2021 10:25pm |
Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68 |
I have 1 I'm not using. I have just fitted a Frontrunner raised towbar so it's just sitting in the boot |
Fri May 14 2021 8:02pm |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 66 |
If you get the detachable towbar (like I have)
Mon May 17 2021 8:50am |
beerbelly Member Since: 28 Nov 2017 Location: Teesside Posts: 27 |
are the detachable ones safe to tow with i am sure i remember a few years back there was storys of folk having issues with them id hate for my caravan to end up off on its own on the motorway |
Mon May 17 2021 5:42pm |
Mon May 17 2021 7:23pm |
thanks my last range rover had the heavy duty fixed towbar .i wasn't sure when i get my new one if it was a removable if i should change it for fixed |
Tue May 18 2021 5:13am |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 |
I'd second getting the plate. A quick bolt on and it certainly gave me peace of mind when towing a motorcycle trailer last year from Southern Spain to North Scotland! 2010 TDV8 - current - my first RRS, loving it so far...... 2005 Cayenne S - handling defied physics and what a sound, so sod the mpg! 1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim Lots of other non 4X4's in between times......... |
Tue May 18 2021 8:54am |
