Home > Maintenance & Modifications > Side steps with overfinch kit |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4970 |
If you have the full O/F kit with the door lower panel trims then you can not fit sidesteps unless someone has specially adapted the sidesteps in some way, because the o/f lower trims extend down past the bottom edge of the door where the step would be. Top picture shows O/F door panels fitted. Lower picture my own car with O/F bumpers but without the lower door panels fitted as needed sidesteps for her indoors, you can see the difference in depth.
Sat May 15 2021 10:01pm |
Topham Member Since: 15 May 2021 Location: Chester Posts: 4 |
Mate that’s perfect explanation
Sun May 16 2021 8:57am |
Mine |
Sun May 16 2021 9:00am |
