Home > Faults & Fixes > fault code
barron alan
England 2006 Range Rover Sport 4.4 V8 HSE Java Black
fault code
Hi all i have fault code P0441 evaporative emission system incorrect purge flow.
my question is what is this
Post #613654 Fri May 14 2021 7:18pm
Basically this.
Out of interest do you have any starting issues with the car either hot or cold, the purge valve itself is located at the rear of the engine, the charcoal cannister is up by the ebc module in front of the spare wheel.
Post #613666 Fri May 14 2021 10:13pm
barron alan
Thanks for that info col . i have no problems with it starting or running just check engine light.
thanks again regards Alan.
Post #613673 Sat May 15 2021 7:46am
