Home > General (L494) > 4-zone climate vs 3-zone |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 |
I have 4 zone climate and have vents each side above the rear doors where the internal lights are and also a rearward facing vent on either pillar between the second row seats and the boot. Hope that helps, mine is an MY17. |
Wed May 12 2021 3:03pm |
ecs0set Member Since: 29 Apr 2021 Location: Poole Posts: 34 |
Excellent, thanks. I suspect there are a lot of 4-zone claims that are only 3-zone - because 2 controls in the rear!
Wed May 12 2021 4:01pm |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 142 |
Ditto MrM
Wed May 12 2021 4:04pm |
Mine is also a 2014.5 model year.
Thu May 13 2021 4:34am |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 457 |
Im pretty certain that if it has the climate digital controls in the rear that it has 4 zone climate. Cars that dont have it only have the heated seats buttons in the back no other heating controls. Are you sure the climate is not set to auto mode where the driver climate adjusts the passenger controls too? It may not be auto mode but im sure there is a way it does this |
Thu May 13 2021 5:56am |
As I understand it, 3-zone is standard on AB (compared to 2-zone with no rear controls) but although there are two controls in the rear, both sides are locked to the same temperature. Same if you adjust through the front screen, even if 'Sync' is not selected.
Thu May 13 2021 5:59am |
I’m always slightly baffled by zoned climate anyway, how effective is it in practice? If it was me I wouldn’t worry from
Thu May 13 2021 7:35am |
It would be useful for me. One of my daughters gets a little motion sickness and likes the temperature ice cold. Seems a shame to have to freeze the other daughter as well but there we go!
Thu May 13 2021 7:40am |
LR registered mine on Topix with 21" wheels as I ordered it, but when it got to the dealer it had 22" alloys, when I enquired why I was told that LR had supply problems with the wheels I spec'd so upgraded the build to 22"s free of charge. I then moaned about the increased costs of tyres over the life of the vehicle and got a £1K refund - Big result! |
Thu May 13 2021 8:48am |
Fair enough. I stand corrected. |
Thu May 13 2021 8:55am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Buy her a thick jumper or a nice travel rug. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu May 13 2021 11:50am |
Heremyjill Member Since: 01 Jun 2020 Location: Shrewsbury Posts: 89 |
Hello,
Wed Apr 19 2023 12:30pm |
Tested mine at the weekend. The rear fan control is directly linked to the front fan control. If you turn the rear fan control up, the front fan control also increases.
Tue May 02 2023 8:13am |
Thank you for the update
Fri May 05 2023 8:31am |
