Home > Wheels & Tyres > 275/40/20 to 275/45/20 tyre change and CCF update info
Cymru001
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Hi everyone,
I have just swapped my old, worn out 275/40/20's for a set of 275/45/20 Grabber AT3's. (I was torn between getting the AT3's in the original 275/40/20 or to go for a set of 19" rims and fit 255/55/19 AT3's. Finances and the fact I didn't want to wait for the 19's to arrive helped me to make up my mind!!)
My question to you knowledgeable people is - what settings do I need to alter within the CCF to make it understand I have the new, slightly larger tyres?
I have been in and had a look and I can see I can change the circumference from the current 2220 to 2375 but what about the other settings -
CC KPH off-set? Currently set at +2.0kph
CC Speed Scaling Factor? Currently set at 3.5% (According to https://www.tyresizecalculator.com/tyre-wh...dimensions - the difference in tyre wall size means my speed will be 3.8% greater than the speedo reading do I change 3.5 to 3.8?).
Tyre (Spelt tire in the CCF Censored ) Aspect Ratio? Currently set at 40%
Trip Fuel Eco Adjust? I have no idea what this means but it is currently set to 7.0%
Tyre Rolling Radius? Currently set to 359 - 275/40R20. There is no option that I can see which has 275/45R20. Do I simply select 375 from the list? That said, I did read a post about measuring from the floor to the centre of the wheel. Which is correct?
Tyre Size MSB - IPC? Currently set at 31 (Having also looked at https://tiresize.com/comparison/ it would appear this number may need to be set to 29.7 for the larger tyre?).
A lot of questions but I would really appreciate any advice you could give. Bow down Thumbs Up
Thanks,
Andy.
Post #613390 Fri May 07 2021 12:12pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Before altering the ccf, try checking your RRS indicated speed against your phone GPS. After fitting 275/45R20's my speedo is now as good as bang on where 275/40's were about 3mph below GPS speed. I'd expect a more accurate speedo would likely make the other settings more accurate aswell 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #613398 Fri May 07 2021 8:35pm
Don't bother changing anything it will not make any noticeable difference to any of it. The new size tyre will actualy make the speedo slightly more accurate.
Post #613403 Fri May 07 2021 10:04pm
Stevepd
Have a read
https://www.rrsport.co.uk/forum/topic57124.html 2006 2.7 TDV6 HSE in Cairns Blue.
Post #613408 Sat May 08 2021 5:55am
Cymru001
Col wrote:
Don't bother changing anything it will not make any noticeable difference to any of it. The new size tyre will actually make the speedo slightly more accurate.
Thank Col. I also read your other posts sent via the link by Stevepd. Interestingly, and I'm not sure if it's my imagination, but the car seems to be accelerating a lot more smoothly. There is also a noticeable difference in ride quality. Even though I had read there would be, I was surprised at how noticeable it actually was!!
Post #613451 Sun May 09 2021 9:00am
