Home > Maintenance & Modifications > Mirror Folding in too far
adamone
Switzerland
Hi All,
I have done a fairly extensive search here and on other forums, but so far didn't find anything to solve my issue.
The wing mirror upon folding in, hits the window and creaks a bit at the last step.
Anyone know if if can be "re calibrated"? or manually pushed out a bit?
I'm concerned its going to damage the mechanism if I keep letting it do that...
Anyone had this issue before?
Cheers,
Adam
Post #613116 Fri Apr 30 2021 10:36am
gogsy1956
Have you tried pulling it back to its " normal " position. I'm sure there is an amount of free play in the mechanism to allow movement in the event the mirror is accidentally hit,, saving it from being broken off otherwise. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #613121 Fri Apr 30 2021 4:55pm
adamone
Switzerland
Thanks for the suggestion.
Yea I tried pulling it out a bit. But the thing is; it has a mechanism built in to allow for some movement if it gets knocked.
If I push the mirror outwards it goes, but the first thing that happens I fold the mirrors in is they click back to the original position.
Basically the only option I am left with is to gently go swing on the mirror I guess........
Post #613293 Wed May 05 2021 3:39pm
