Home > Technical > Restricted Performance AND engine light.....HELP PLEASE! |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Could be a split inlet manifold. You can check it by putting the engine under load. Have the gearbox in drive, foot very firmly on the brake pedal, add the throttle and it'll rev to around 2500rpm. With the bonnet open, you should hear a hissing noise if the inlet manifold is split. That's as my garage informed me when mine went, anyway. 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 26 2021 6:34pm |
MallorcaNick Member Since: 03 Jan 2021 Location: Mallorca Posts: 50 |
That's one of the popular opinions too, so makes sense. Thank you.
Mon Apr 26 2021 7:18pm |
Sorry, you won't like the answer... 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 26 2021 9:07pm |
Mafya Member Since: 05 May 2020 Location: Sheffield Posts: 46 |
Manifold cost me £410 from Land Rover dealers and my usual garage charged me £200 labour when mine went |
Tue Apr 27 2021 12:35am |
That doesn't seem too much to fix the problem, to be honest. I would be relieved if that's all it cost me.
Tue Apr 27 2021 9:11am |
keith63 Member Since: 02 Sep 2019 Location: south staffs Posts: 78 |
i had exactly same problem , fortunately a local indie fixed mine cost approx £550 ,
Tue Apr 27 2021 9:52am |
+1 for inlet manifold / manifolds.
Tue Apr 27 2021 11:29am |
Thanks all, so much.
Tue Apr 27 2021 8:39pm |
You can drive it, just do it gently. Basically, what happens is that you give it a bit of throttle and the negative pressure in the manifold causes the split to open sucking in air. This then leads to an imbalance in the fuelling because it effectively runs lean. The ECU picks it up because the exhaust gases don't "taste" right to the sensors.
Tue Apr 27 2021 10:18pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
There is no need to get towed, if it is the manifold. The vehicle only goes into limp mode to comply with emission regulations. There could be loads of older motors that have inlet manifold leaks, but legislation did not stipulate they have to throw a tantrum.
Wed Apr 28 2021 8:47pm |
3k miles in 2 years? It's probably throwing issues out of boredom. Get out there and drive it! 2012 SDV6 - it's missing a couple of cylinders
Wed Apr 28 2021 9:34pm |
Thanks all.
Thu Apr 29 2021 3:43pm |
I don't do to many miles, as my local indy isn't too far, that's the only run it gets, to replace inlet manifolds and handbrake. . Off to Wales in May, so should hopefully put a few miles on. Don't get me wrong, she doesn't go wrong much, but she does pick the worst times, when I don't have time to fix her myself. MY12 RRS HSE Gone 4.2 supercharged RRS Gone 90 Gone s2000 |
Thu Apr 29 2021 5:28pm |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 257 |
Just a personal observation, but the more regularly I used my car, the more reliable it seemed to be. I used to be quite a high miler (>25k for nearly 20 years) and seemed to have less bother than mates who just had relatively short commutes. Age of vehicle was not a factor, I always bought ex-company cars >3 years old with 70-80k already on the clock. RRS HSE Dynamic SDV6 2014
Fri Apr 30 2021 8:47am |
