![]() | Home > General (L494) > PDC |
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 ![]() ![]() |
Anyone know where the parking aid ecu lives in a 2015 RR l494 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
In the boot, behind N/S trim panel towards the top.
Finally found it it sits on top of the keyless entry ECU |
So finally got to the bottom of the long beep when in the car after 40-50 seconds of start up Parking ECU locked up for some reason cleared the faults using a GAP tool and as my car has blind spot detection but no rear traffic detection when reversing I thought I would enable it to see if it works and like a charm it does and you can select or deselect in the menu. |
