![]() | Home > General > Key fobs not working |
Drobe Member Since: 11 Jun 2020 Location: Warwickshire Posts: 9 ![]() ![]() ![]() |
Ok guys, I have a issue with key fobs not working, when’t to open car the other day and no of my key fobs worked, car has never had this issue before!!one of my fobs is brand new a couple of months ago so fob batteries aren’t the issue. Been looking through a number of forums on issue one issue keeps popping up is the three green wires connected together in wiring loom on passenger side but it’s relating to D3 my question is it the same on RRS? |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
I had same problem. I pulled fuse out of boot fuse box relating to keyless entry, fuse 45 I think and all ok now. Or disconnect battery and should do the same trick. I think the problem will be to do with the KVM module but mine has been ok since fuse pulled out. |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 240 ![]() ![]() ![]() |
When my keys did this i had to have a new KVM module fitted. |
Even though my fobs or keyless entry didn’t work I could still lock and unlock my car with the app on my phone. Have you tried this? |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 ![]() ![]() |
Hi Johnrrs... thanks for the info, I will try pulling the fuse today. Hopefully that sorts it out. I haven’t tried with the app I will try that now. Any idea where I can find out what fuse it is for certain? Also should this be done with the ignition on or off? 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Its in the handbook under fuses somewhere. Ignition off. There are 2 fuses in the handbook in relation to keyless entry. I pulled both of them out. When i put one back in i heard a rekey click and hey presto everything worked. The fuse box is behind a panel on the right in the boot. Be careful not to break any clips like i did. |
My hand book says the KVM modules are in the glove box fuse box? I have my16. What year is yours John please? 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Mines a 2015 plate but 2016MY |
That’s the same as mine 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Is it the passive locking fuses you pulled John in the boot? 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Yeah it could be marked down as that. |
Just removed fuses 48 and 57 (passive locking) and hey presto! All sorted. Thanks Johnrrs 2016 Yulong White L494 AB/DYN 3.0SDV6 |
That’s good news. Mine did it again2 weeks later so did the same thing and has been ok ever since. I’m sure it will happen again in the future and if it does it more frequently I’ll get it looked at. I’m sure it’s the KVM module that’s on its way out possibly. Did the locking work with your app? |
At least we know how to sort it now and anybody else it happens to.. amazing how many times this forum has saved me going to the stealers! I noticed there is a few spare fuses in the boot space as well. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
