Home > General (L494) > Moisture in rear light. Is it warranty |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 133 |
Hi, My car is still under Land Rover official warranty till August. I have noticed that one of the rear light clusters has developed some moisture on the inside. Do you think warranty would cover this? Current - 2020 Range Rover Sport P400e
Thu Apr 22 2021 1:27pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 901 |
Yes it will. Just noticed its 2014, maybe not. Just ask |
Thu Apr 22 2021 2:45pm |
I bought the RRS in August last year from a LR dealer with the 12 month LR approved warranty. Current - 2020 Range Rover Sport P400e
Thu Apr 22 2021 3:00pm |
Thanks, will monitor that Current - 2020 Range Rover Sport P400e
Thu Apr 22 2021 4:03pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
I gave mine a wash today, condensation in the rear clusters which had gone by the time I'd finished wiping it over with quick detailer. My old D3 was exactly the same. Providing it clears itself I wouldn't worry about it (from memory there is something about it in the handbook). |
Thu Apr 22 2021 7:20pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Not sure about the RRS2, but it is certainly mentioned in the RRS1 owners manual under exterior lights, only mentions h/lamps but would assume refers to rear lights as well.
Thu Apr 22 2021 8:34pm |
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 |
Yes it should, I had a discoverySport 2 years old and it (LH Rear) was replaced under warranty. |
Thu Apr 22 2021 9:58pm |
Frems Member Since: 17 Mar 2020 Location: Aberdeen Posts: 2 |
I had the same not long after I bought mine and the dealer refused to change them under warranty - said they were too expensive!!! |
Tue May 18 2021 9:06pm |
Wed May 19 2021 9:03am |
kevin reevse Reeves Member Since: 21 Sep 2020 Location: Windsor Posts: 20 |
My 2015 has condensation in rear light and dealer said its normal and wouldn't change it under the 12 month extended warranty. Was thinking about purchasing the after market sweeping indicator ones as the condensation annoys me. |
Mon May 24 2021 7:52pm |
ct83 Member Since: 15 Apr 2018 Location: Germany Posts: 3 |
I do have this problem as well. Does it also appear with aftermarket tail lights? |
Wed Feb 23 2022 11:49pm |
