![]() | Home > Maintenance & Modifications > 2.7 Upper sump gasket replacement |
the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64 ![]() ![]() ![]() |
Sump removal
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Wow, a nice detailed write up. Confirms to me everything I need to know about the job. And why I pay a nice man to do things for me! |
paul_wood Member Since: 17 Apr 2021 Location: Hertfordshire Posts: 8 ![]() ![]() |
Wowza Thank you so much! That’s super duper helpful I actually feel much more confident now! I’m tackling this evenings and weekends around my long a*** job! |
Keep me posted. If anything comes up along the way, no worries with you asking here or dropping me a message and I'll do my best to help out.
Already in the thick of it. The steering link was unbolted and the wishbone was unbolted on one side all fine, on the other side the upper wishbone nut came off easy enough but the joint refused to come out. Hit it a bit hard and it came out but I think I |
It’s ok if it spins |
Thanks!
Humm. I don’t recall when I did the front.
Glad you’ve got so far |
Oooookay. Just got time to carry on. Managed to get all the bolts out the prop.
I struggled getting the driveshafts out too, and gave up.
Persistence is the only way. They are designed to come out. Continual sharp tugs and a good pair of gloves to save your knuckles when it suddenly comes out.
Still no luck getting them free. Looks like the O/S extension tube has been cemented on to the diff.
I think you need to remove the air Con compressor 13mm bolt on the passenger side. You need a UJ joint for this. (maybe this is the long one you talked of)
I think you are questioning the engine to gearbox bolts. Yes the 2 by the starter need removing. I can't remember what's on the passenger side. There maybe 1 that needs removal. As you are gonig the slide out method, you will find there are 2 tiny PAS pipes that need disconnecting, and fluid will leak out. |
