Home > General (L494) > Oil level
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Oil level
Hi I’ve been keeping an eye on my oil level lately after reading all the camshaft snapping issues due to low oil in engine (possibly). I check when engine cold on a flat surface and oil level is on max. Land Rover recommend checking oil level when engine is warm and after 10mins of been parked up. Again when I check it the oil level is on max which is good. Should the oil level be lower when the engine is warm or same as when cold? I don’t know why LR tell you to check when engine is warm. I always assumed you check oil levels when engine is cold.
Post #612049 Sun Mar 28 2021 9:53pm
Turdmon
Now then John. Thumbs Up
You will get a slight volumetric increase in oil when the engine is up to running temperature and the level should not be over maximum at this point.
Post #612753 Sun Apr 18 2021 8:52am
Johnrrs
All ok , with mine then as it just stays on max when cold or warm, no overfill sign on screen.👍
Post #612761 Sun Apr 18 2021 4:20pm
