Home > In Car Electronics > Retrofitting heated steering wheel RRS MY2010 |
at31916 Member Since: 29 Mar 2017 Location: Cumbria Posts: 6 |
Has anyone done a steering wheel upgrade to heated on a MY2010 onwards? I’ve got the steering wheel, I believe the clock spring is required to be changed? What other work is required to enable the steering wheel to work?
Fri Apr 16 2021 11:44am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Is the steering wheel complete? otherwise you will need R/H switch pack. I think you may have to have it activated in the CCF files as well but may be plug and play, easy enough though. There is only One clock spring for the heated wheel LR018556 biggest percentage advertised on flea-bay are not for the heated wheel.
Fri Apr 16 2021 10:09pm |
To start with you may need to make sure you have the correct heated steering wheel clock spring, can't really remember if you can see connector plug on the back by just removing cowling around the indicator/wiper stalks but would think you can, also is it actualy a heated wheel and not just a switch pack someone has fitted. If that's all good could check No. 20 fuse passengers side fuse box.
Sat Apr 17 2021 12:27am |
Sat Apr 17 2021 6:30am |
Mon Apr 19 2021 1:48pm |
Hi'
Mon Apr 19 2021 9:53pm |
Update
Mon May 17 2021 1:06pm |
