![]() | Home > General (L494) > Auto stop / start not working |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Battery problems are common in older cars where they have two batteries. In my D4 there was a bad batch, so it is possible. Should be easy for the dealer to check........famous last words |
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 ![]() |
Charge your 12V battery overnight and see what happens the next day. |
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 ![]() ![]() |
Concur with KOT - stick it in a trickle charger and should be sorted MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
Kenniff Member Since: 04 Feb 2021 Location: London Posts: 55 ![]() ![]() |
Thanks all.
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
Charge the battery (it may have been stnading for a while (as in on the shelf) and all the checks etc... could just be low.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 915 ![]() ![]() |
It does not take long for the battery to be low enough for the stop/start not to work. Short journeys, few things on, including wipers & lights. If locked the alarm is taking some power. My car is only used once or twice a week, but always on a Ctek. No problem with stop start.
Same I added a couple of the CTEK quick connectors so I could easily plug in. Have them both in tail (mine is an older car so has 2 batteries from 2016 on I think they used capacitors so a new car will probably us that unless it hybrin then its not an issue.
As pjbracer1, I also have Ctek quick connect in boot & another in the front which appears from the slot just above number plate so I do not have to open the bonnet & when disconnected it hides inside the slot area. Same here, sitting at lights for a while it switches off then sometimes fires up the engine, so it shows how sensitive it is. Also noticed if you only have your foot on the brake very slightly it will not switch off, but a bit more pressure & it will. I do this at certain junctions where you have to "force" yourself out into the traffic & do not want it switching off. |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
As part of my routine, my finger goes to the 'eco' button turning the stop/start off, straight after the engine start button.
If you got a GAP Tool I think you can disable it. I dont mind using it in and around town in the summer when windows are open etc... and its seems a bit of a waste just burning fuel in a queue (im not a greeny, just think we waste alot of resources)
