![]() | Home > General > 2012 RRS Service and any other essential maintenance |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
If it hasn't been done, possibly at 71k transmission oil change/flush.
RRSSDDUB Member Since: 31 Mar 2021 Location: NE Posts: 28 ![]() ![]() ![]() |
gearbox flush is on the list but i have read conflicting reports if to do it or not - no issues with the box atm and very smooth changes.... just to add it states timing belt and injection pump belt changed at 57k. |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
You’re in good shape! If you have factory side steps have a look underneath, they are the first things to rust off the car. I just replaced mine on a MY12 with 96k. 2018 Telsa MS
yes factory sidesteps need some TLC too, not rotten through but starting to rust so may just clean them up and paint until they need replacing ! Where did you get you replacements from? |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 ![]() ![]() ![]() |
I wouldn't. Had mine done at about 68k i think on my RRS1 with the adaptations reset and it was less smooth. Even got it done again at a local garage and it wasn't much better. Will be leaving this one well alone i think unless there's a specific problem i'm trying to fix down the line. L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
Gearbox flush on both of my cars, although neither had issues before, change much smoother after, and down changes greatly improved.
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi both cambelts. |
yes im still unsure.... |
i presume this is the injection pump belt? so hopefully all done!! ![]() |
I wasn't sure on the timing belts on mine so decided to have it done so i knew.. L494 3.0L SDV6 Autobiography in Chile Red (Current)
Had my 2013 RRS belts done 62000 in Feb 2021 didn’t want to risk the RRS gremlin getting to work lol |
