![]() | Home > Technical > help please |
tolley Member Since: 12 Nov 2018 Location: gloucester Posts: 9 ![]() ![]() |
sport just started doing this this morning ticks over then starts fluctuating then cuts out . |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
I assumed that the low fuel warning was a false code along with the washer fluid low and check all tyre pressures. Had it just been that it was low on fuel, it would make sense for it to cut out as it has a protocol which shuts the engine down to prevent any damage as per the sender wiring fault.
many thanks gent i will and report back , thank you again |
yes seems ok now , just needed a drink |
