Home > Maintenance & Modifications > Premium diesel recommendations ?? |
Phileep Member Since: 04 Feb 2019 Location: LEIGH-ON-SEA Posts: 52 |
It does appear that two divisive topics are those about petrol and oil
Wed Apr 07 2021 6:38am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 899 |
Everything about cars is subjective, if your happy to try something, so be it. To reverse your question, is there any proof its harmful. When I was young my dad used to put in 4 gallons of fuel & 4 skoots of Redex into his car which brought the total spend up to £1. Did it do any good, debatable, just like any other additive. My post is a bit tongue in cheek. I don't advocate using it but thought after reading the full article which is a hard read not just someone's comment, I would give it a try |
Wed Apr 07 2021 7:35am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
My concern is that with ever more increasingly complex emission control systems being added to modern cars, adding stuff like 2-stroke oil to the fuel might be a recipe for disaster. If the emissions control systems get in a tizzy, they will effectively stop the car at the side of the road.
Wed Apr 07 2021 8:25am |
Windydog Member Since: 13 May 2021 Location: Tetbury Posts: 7 |
I'm the same, running 2EHN like Millers will give the cetane a bump, lubricate the fuel pump, clean the IVDs, and at 1000parts per million dose rate. Works out approx 3.3ppl vs 14ppl or more. I'll standby for incoming, but there is no physical segregation of fuel between brands at fuel terminals. Same BS EN 590 beer. different landlord, with an additive differential not worth noticing or mentioned. |
Fri May 14 2021 4:03pm |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 |
Shell V-Power for me, every fill up. Its crept over £1.50/L now so it stings a bit L494 3.0L SDV6 Autobiography in Chile Red (Current)
Mon May 17 2021 9:12am |
Shell changed the additive recipe on V Power I think. I notice they have dropped the PERL (GTL) component out and reformulated under a "Dynaflex" moniker. To be honest, I don't know what this means, they don't give a composition. V Power is very well rated, but i'm finding it a little anecdotal to be fair.
Mon May 17 2021 1:01pm |
Please elaborate L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
Mon May 17 2021 1:53pm |
Nail hit squarely on the head!! 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon May 17 2021 6:39pm |
beerbelly Member Since: 28 Nov 2017 Location: Teesside Posts: 27 |
i always took the benefits of the premium diesel with a pinch of salt thinking its just an extra additive pack how can extra detergents make a difference to performance until i put a bottle of injector cleaner and a bottle of turbo vane cleaner into a full tank of fuel the truck definitely ran smoother and felt just generally happier . i cant explain it but i also noticed a difference when i put my next tank of billy basic supermarket fuel in .so i am a convert to premium fuels |
Mon May 17 2021 6:50pm |
