Home > Maintenance & Modifications > Range Rover won’t start after Fuel Filter change
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi lads
Need some help. Changed the Fuel filter on the 2006 2.7tdv6 as I have done many times before. But today it now won’t start. I have not changed back to the old Filter but it still won’t start. Turns over but won’t kick. The pump in the tank appears to be running as I can hear it. Any ideas would be much appreciated not sure if I should keep cranking it if it’s delivering fuel into the engine Crying or Very sad
Post #612210 Fri Apr 02 2021 3:18pm
Jock 77
Sorry I have changed back to the old filter it should read.😞
Post #612211 Fri Apr 02 2021 3:24pm
Turn the ignition on for 30 seconds then off. Repeat three times.
Use the bleed valve at the back of the engine to get air out
Post #612213 Fri Apr 02 2021 4:38pm
Jock 77
Thanks Andy
My own fault there was a lot more air appeared from somewhere. Never had it as bad as this before. Now started and new filter refitted. Thanks lads
Post #612214 Fri Apr 02 2021 4:53pm
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Same for v8 Dieasal? Please
Found it !
Post #618581 Sun Oct 31 2021 7:03pm
