![]() | Home > Maintenance & Modifications > ICARSOFT LR V2 Diagnostic |
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 352 ![]() ![]() |
What price did you see it at ? |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi £136.00 |
Not bad 👍
I know it’s not as good as the IIDOBD BT Gap but at £435 cant justify that at present and the reviews I’ve seen are good and the functions it gives are a good range for your home mechanic. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Out of curiosity, does this allow recalibration e.g. suspension, SAS and give live injector values. I'm assuming it will read full fault codes. |
Have you a link to where to buy it |
Hi go to ebay and put this item code in eBay Item No. 303310232150 . |
The Latest version for iCarsoft LR II/ LR V1.0 enjoys special functions such as oil service reset, EPB, SAS, DPF, ETCs, battery test, data print and review and battery management systems (BMS). Recent upgrades include ABS bleeding and injector programming.
