![]() | Home > Faults & Fixes > L320 seat belt bolt |
L/R don't appear to list the bolt you are looking for separately, might be a breaker's yard job, or you could try a rear seat one but again still two different sizes 10mm and 12mm thread.
Steve1978 Member Since: 30 Mar 2021 Location: Liverpool Posts: 4 ![]() ![]() |
That’s interesting. I didn’t expect it to look like that if I’m being honest. I expected a stalk that just bolted to the seat.
I don't know for sure but would assume it bolts to the sliding part of the seat frame, so it moves with the seat and and is quite securely mounted to do it's job.
Perfect. Thank you Col. |
I can confirm that the lap component of the set belt bolts to either side of the seat. 07MY RRS TDV6
