Home > Faults & Fixes > Engine misfire cylinder 1
ach2
Hi All,
I have today had a bit of lumpy running and fault codes
P0301-00 (74) Cylinder misfire detected
P0316-00 (74) Misfire detected on startup (first 1000 revolutions)
Codes were read on the GAP IID tool. I can clear these but they re-cur and put the car into a limp mode.
I gather these faults can be caused by plugs, coil pack or injectors. The plugs were all changed approx 18 months (less than 4000 miles) ago, so probably not those.
The car is a 2005 RR Sport, 4.2 supercharged with approx 125k miles.
Any ideas where to start looking?
Thanks,
Alan.
Post #611772 Mon Mar 22 2021 6:51pm
knwatkins
If I were you Alan, I would start by swapping components one at a time between cylinders and see where the fault moves. That way, you'll be able to identify the correct component to replace. Kev
Post #611774 Mon Mar 22 2021 7:05pm
ach2
Cheers for the reply. I've ordered a couple of coil packs as not too expensive. If it solves the problem then I'll probably change the other 6 later as they're probably all the same age. If it doesn't solve the problem then further digging needed.
Post #611788 Tue Mar 23 2021 8:58am
ach2
Just thought I'd close this one out.
I bought a used coil pack and fitted it this morning. Job took approx 20 minutes and everything working fine again.
Not sure if I'm going to keep the car, but if I do I'll change the set for new ones as they're all the same age (ish).
For info, bought the part for £12.95 from 'Gentlemen of Salvage'. I've used these guys before for some very cheap and sometimes quite expensive used parts. Their stuff always works so I'm happy to plug them - the stuff also arrives cleaned and generally tested, and pretty quick.
Post #611971 Sat Mar 27 2021 9:31am
knwatkins
Great news Alan.
I've used Gentleman of Salvage before too. They've been very helpful and always provided a good service. Another thumbs up here. Kev
Post #611974 Sat Mar 27 2021 11:28am
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Second from me, very good people and parts always top notch. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #611988 Sat Mar 27 2021 12:27pm
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
And a third from me, pleasure to deal with every time. Thumbs Up
Post #612027 Sun Mar 28 2021 1:19pm
