![]() | Home > General > Noisiest air bags in history |
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 123 ![]() ![]() |
Sorry I can't help with your dilemma.
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 ![]() ![]() ![]() |
Think its probably your Anti Roll Bar Bushes rather than your Airbags.. Silicone spray lube helps temporarily. Some replace with poly instead of rubber (replaced mine original). L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9039 ![]() ![]() ![]() |
Very possibly the hub bushes - the ones that connect the upright to the suspension arms. They will squeak just like that. You can get them to squeak just by rocking the car when it's parked up at normal height. 2012 SDV6 - it's missing a couple of cylinders
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5026 ![]() ![]() ![]() |
Put the suspension up and down with park break off, and gear N
Thanks for the replies.
Changing the suspension height doesn't prove the air bags are the issue. Everything in the suspension moves when the height changes. All you are doing is proving that the noise is coming from the suspension.
Thanks for the replies. Am hoping it is the hub bushes rather than air bags. Though 2 x them is way cheaper than 2 x inlet manifolds or a pair of turbos, as I know from experience.
