![]() | Home > Maintenance & Modifications > 2.7 Upper sump gasket replacement |
Have you got the workshop manual? Be worth downloading it if not. 2012 SDV6 - it's missing a couple of cylinders
Remove fan and aux belt
the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64 ![]() ![]() ![]() |
Awesome, so it comes out the top?
From memory, the front diff has to come out to lower the crankcase down |
Wondering if the crank case can be lowered just enough to slip the new gasket in, but now problem dropping the diff if I need to. |
I’ve got it out without removing the diff.
That's good news. I think I am going to start again from scratch with timing belt and oil pump off, then crank case off, then remount the pump and time it up then crank case back on with new gasket to seal from below properly.
personally I wouldn't remove the oil pump.
Been working on this today. I can't say it was an easy job, but I guess that is to be expected!
A further note on this.
paul_wood Member Since: 17 Apr 2021 Location: Hertfordshire Posts: 8 ![]() ![]() |
Hey! I have a disco 3 and notice this thread may be applicable.
Not sure ill get down to Herts in a reasonable timeframe to be of any help, but it sounds like youve made all the right progress in getting the oul pump out so its not such a big job from here.
Fantastic! Shame you can’t be around but what you’ve sent is already making me feel more comfortable about moving forward with this, and so I look forward to any more advice you can offer, much appreciated, thank you! |
No problem at all.
