Home > Technical > Which Remote Heat Receiver to install?
Leechicken74
Hi, I currently have timed heat on my 2010 TDV8 and I want to retrofit the remote heat function, I don’t need any SMS/TXT functionality I just need a remote option to get things warmed up before I leave the house. I have a GAP tool so can change the configuration etc
I have searched the forums and found some recommendations and even some part numbers but there is some inconsistencies around which unit is the correct one, so could someone confirm if I need a T90, T91 or T91R receiver and then which key fob to match?
Many Thanks Lee
3.6 TDV8 2010 (facelift) HSE Stornaway Grey
3.0 TD6 2018 Discovery HSE Luxury Indus Silver Dynamic Packs 1 & 2 - Sold due to COVID budget cuts at home 😢
Mini Countryman 2.0 Cooper SD All4 - White, black wheels, black decals - Great little car and so much fun!
Post #610913 Tue Mar 02 2021 8:23pm
Leechicken74
Quick bump to see if anyone can help please? Lee
Post #611370 Thu Mar 11 2021 9:43pm
knwatkins
Hi Lee, it's a T91 you'll need eg. 8H52-18D540-AA
When buying the remote, make sure you get the correct one. It should have an 'ON' button and not a heating element button.
Don't get this one:
Get this one:
 Kev
Post #611406 Fri Mar 12 2021 9:38pm
Fifth Horseman
Valid part numbers are :
Transmitter - LR009736 superseded by LR027493 (Engineering pt. no 9H5218D539AB/C) also used in FFRR 2010-2012, Freelander 2 2006-2014 and Disco4
Receiver - LR008656 superseded by LR027717 then superseded by LR036695 (Eng pt no 8H5218D540AA/B/C) T91 or T91R (also used in Disco4)
Do not be fooled into thinking this remote being sold on eBay for the D4 will work - it won't, its for the Eberspacher heater fitted to the L405.
Post #611482 Sun Mar 14 2021 8:03pm
